以下资料是回应网友要求,发出来的。帆船型号是Dix 43PH
Her vital statistics:
LOA...43’10” ( 13.35m)
LWL...38’11” (11.87m)
Beam...13’5” (4.10m)
Draft...5’11” (1.80m)
Displacement...31,517 ;bs (14,300kg) half load
Lightship Dry Weight ....26,400 lbs ( 12,000kg)
Ballast...12,100 lbs ( 5500kg) lead
Sail Area...984 sq. ft. (91.44 sq.m)
D/L ...238
SA/D...15.7
LISTS OF MATERIALS FOR HULL & DECK
The following lists of materials are approximate and intended only for calculation of approximate costs. Theyare not intended to be used for the ordering of materials for construction.
Lengths and areas are based on the actual amounts to be used in the vessel without any allowance for building stocks, temporary framing, bracing etc nor for wastage in cutting to size and shape as required. Wastage on flat bars, tubes etc will be minimal whereas that on plate will be dependent on the skill of the builder and will be in the range of 5% to 20%.
MATERIALS FOR STEEL HULL AND DECK
3mm (1/8") Plate - 57sq.m (614sq.ft) - Deck, anchor locker, tanks, rudder
4mm (5/32") Plate - 32sq.m (345sq.ft) - Hull side skin, transom
5mm (3/16") Plate - 20sq.m (216sq.ft) - Hull bottom skin, intermediate floors
5mm (3/16") Plate (radiused) - 30sq.m (323sq.ft) - Hull radiused skin
6mm (1/4") Plate - 13sq.m (140sq.ft) - Keel, skeg, engine beds, rudder
8mm (5/16") Plate - 3sq.m (33sq.ft) - Floors
20mm (3/4") Plate - 0,35mx3,50m (14"x12' ) - Keel sole
30x6mm (1 1/4x1/4") Flat bar - 29m (96' ) - Tanks
40x6mm (1 1/2x1/4") Flat bar - 123m (404' ) - Frame flanges, deck stringers
40x8mm (1 1/2x5/16") Flat bar - 58m (191' ) - Hull stringers, Transom stiffeners
50x8mm (2x5/16") Flat bar - 95m (312' ) - Hull stringers
75x8mm (3x5/16") Flat bar - 14m (46' ) - Centreline stringer, engine bearers
90x8mm (3 1/2x5/16") Flat bar - 43m (142') - Frames
100x8mm (4x5/16") Flat bar - 5m (17' ) - Chainplate brackets
40x10mm (1 1/2x3/8") 316 S/S Flat bar - 2m (7' ) - Chainplates
50x50x8mm (2x2x5/16") Angle - 36m (119' ) - Deck beams
60mm OD x4,5mm (2 1/2x3/16") wall tube - 6m (20' ) - Keel, skeg, stern tube, rudder
75mm OD x4,5mm (3x3/16") wall tube - 27m (89' ) - Mast support, rubrails
102mm OD x6mm (4x1/4") wall tube - 0,7m (3' ) - Rudder port
33,4mm OD x2,77mm (1 1/4x1/8") wall 316 S/S tube - 27m (89' ) - Sheer tube
60mm diam (2 1/2") 316 S/S bar - 1,4m (5' ) Rudder shaft
MATERIALS FOR ALUMINUM HULL AND DECK
Plate is to be of alloy 5086 and extrusions are to be of alloy 5083 or their respective equivalents.
4,5mm (3/16") Plate - 57sq.m (614sq.ft) - Deck, anchor locker, tanks, rudder
6mm Plate (1/4") - 52sq.m (560sq.ft) - Hull skin
6mm Plate (1/4") (radiused) - 30sq.m (323sq.ft) - Hull radiused skin
9,5mm (3/8") Plate - 16sq.m (173sq.ft) - Keel, skeg, engine beds, rudder, floors
32x6mm (1 1/4x1/4") Flat bar - 29m (96' ) - Tanks
40x6mm (1 1/2X1/4") Flat bar - 28m (92' ) - Frame flanges
50x10mm (2X3/8") Flat bar - 72m (237') - Deck beams
50x20mm (2X3/4") Flat bar - 2m (7' ) - Chainplates
100x10mm (4x3/8") Flat bar - 62m (204' ) - Centreline stringer, frames, engine bearers, chainplate brackets
32x32x4,5mm (1 1/4x1 1/4x3/16") Angle or Tee - 153m (502' ) - Hull & deck stringers, transom stiffeners [or use 40x10mm (1 1/2x7/16") flat bar]
40x40x4,5mm (1 1/2x1 1/2x3/16") Angle or Tee - 120m (394' ) - Hull stringers [or use 50x10 (2x3/8") flat bar
70mm (2 3/4") diam Round bar - 1.5m (5' ) - Rudder shaft upper
63,5m OD x6,36mm wall (2 1/2x1/4") tube - 4m (14' ) - Keel, skeg, stern tube, rudder
70mm OD x9,53mm wall (2 3/4x3/8") tube - 1.5m (5' ) - Rudder shaft lower
76,2mm OD x6,36mm wall (3x1/4") tube - 27m (89' ) - Mast support, rubrails
114mm OD x9,53mm wall (4 1/2x3/8") tube - 1.5m (5' ) - Rudder port
32mm OD x3,18mm wall (1 1/4x1/8") tube - 27m (89' ) - Sheer tube
两种材料,钢材和铝合金的清单,请自行查看。
Dix43_PH_Wire_Steering.pdf
(758.62 KB, 下载次数: 88, 售价: 1 贝壳)
