[求助] 求高手翻译帆船比赛信号旗图标
发表于 2014-3-27 14:58 | 显示全部楼层 |阅读模式 来自: 上海青浦区
悬赏1贡献未解决
Flags:
Flag
Sound signals
Indicates
Notes
file:///C:\Users\LEGEND\appData\Local\Temp\ksohtml\wps_clip_image-11245.png
X-Ray
Individual Recall
Hoisted after start to indicate a boat was over the before start time. Race officer may hail the boat that was over to re-cross the line. Flag is lowered after boat(s) that were over re-cross the start-line.
file:///C:\Users\LEGEND\AppData\Local\Temp\ksohtml\wps_clip_image-4284.png
1st Substitute
General Recall
Hoisted after start if Race officer cannot identify all boats over the starting line. Race will be re-started at next opportunity. If Monohulls have general recall, re-start will be 5min. after the multihulls start. If Multihulls have general recall, re-start will be at the next available 5min. cycle after the first start.
file:///C:\Users\LEGEND\AppData\Local\Temp\ksohtml\wps_clip_image-10061.png
Sierra
Shortened Course
Finishing line is either the normal finishing line or in between the Race Committee Boat displaying Sierra flag and a mark on the course.
file:///C:\Users\LEGEND\AppData\Local\Temp\ksohtml\wps_clip_image-7891.png
Charlie
Change of position of next mark
Boats must be signaled at a mark before they begin the next leg of the course.
file:///C:\Users\LEGEND\AppData\Local\Temp\ksohtml\wps_clip_image-10242.png
November
Race abandoned
Race may be re-started if Lima flag is not displayed.
file:///C:\Users\LEGEND\AppData\Local\Temp\ksohtml\wps_clip_image-6365.png
Lima
All boats back to the shore
file:///C:\Users\LEGEND\AppData\Local\Temp\ksohtml\wps_clip_image-19977.png
India
Rule 30.1 in effect
“Round the ends”. If any part of a boat or crew is over the start line or its extensions within the last minute before the starting it has to sail from the course side across on the extension to the pre start side before the starting.
Normally not used at SBYC.
file:///C:\Users\LEGEND\AppData\Local\Temp\ksohtml\wps_clip_image-20607.png
Zulu
Rule 30.2 in effect
“20% Penalty rule” If any part od a boat or crew is over the starting line within the last minute before the starting it shall receive at 20% score penalty without hearing.
file:///C:\Users\LEGEND\AppData\Local\Temp\ksohtml\wps_clip_image-30622.png
Black
Rule 30.3 in effect
“Black flag rule” If any part od a boat or crew is over the starting line within the last minute before the starting it shall be disqualified without hearing.
GMT+8, 2025-5-6 07:38 , Processed in 0.300394 second(s), 32 queries .
