Prout 42米三体船 - 全球最大的整体环氧树脂抽真空制作过程
2014-7-15 21:14 · DIY造船日记
Leonardo 来自: 广西南宁
42米!这么大!这造价
2013-12-16 18:42
totgsky001 来自: 江苏镇江
那个大神有这个船的详细点的资料啊,网上貌似找不到!!求!!!
2014-7-13 15:12
洪运来 楼主 来自: 北京
就这视频都是费老劲从youtube弄来再传我要航海网的,大家一起努力,才有可能
2014-7-13 18:26
totgsky001 来自: 江苏镇江
这个船和其他的三体帆船不同的地方很多,所以想找点资料了解下!!嗯嗯,我在想办法找找看!
2014-7-14 21:10
洪运来 楼主 来自: 北京
找到了么?
2014-7-15 21:00
totgsky001 来自: 江苏镇江
Prout 138 Worlds Largest Sailing Trimaran普劳特138世界最大三体帆船��行
Home首页 &raquorout 138 Worlds Largest Sailing Trimaran普劳特138世界最大三体帆船航行
02 Aug8月02Posted by代传AcronauticAcronauticin在Latest News最新消息|| Comments评论Under construction at Prout International is the second Prout PT-138 catamaran.普劳特在建普劳特国际是第二个pt - 138双体船。
Measuring 42.06m, the Prout 138’is the world largest sailing trimaran and the first sailing trimaran super yacht intended for luxury global cruising. 普劳特测量42.06米,138年世界上最大的三体帆船航行并第一个三体帆船航行超级游艇用于奢侈品全球巡航。The Prout PT-138-02 was infused in early March and construction on both of the world largest sailing trimaran yachts continues.Prout pt - 138 - 02年3月初注入和建筑在这两个世界最大的三体帆船游艇继续航行。
After weeks of preparation, it took only 3 hours for the PT-138 hull 02 to be completely infused. 经过几个星期的准备,只花了3个小时的pt - 138船体02完全融合。The advanced construction method of composite G.R.P. with carbon fiber reinforcements is believed to be the largest single piece epoxy infusion in the world and was completed at the factory in China under the auspices of RINA.先进的施工方法与碳纤维复合G.R.P.增援部队被认为是世界上最大的单一块环氧灌注,完成在中国的工厂的赞助下意大利船级社。
The Prout design PT138 is fitted with a Caterpillar C-12 on the center hull and Steyr Hybrid diesel engines fitted on the port and starboard wing hulls. 普劳特设计PT138装有毛毛虫C-12中心船体和斯太尔混合柴油发动机安装在港口和右机翼船体。The vessel achieves a cruising speed under power of 15 knots. 这艘船达到巡航速度在15节的力量。Computer polar projections indicate excellent boat speeds under sail ranging from the low teens to the 20-knot range with 814.7 sqm (8,771 sqft) of sail area.电脑极地投影显示优秀的船扬帆从低速度青少年20-knot范围为814.7平方米(8771 sqft)的��面积。
The PT-138 sailing trimaran superyachts are expected to be delivered in late 2011 and in 2012 respectively.pt - 138三体帆船航行超级游艇预计将分别在2011年末和2012年交付。
Watch the world’s largest single piece epoxy yacht infusion in the video below.看世界上最大的一块环氧游艇注入下面的视频。
World’s largest sailing trimaran Prout PT 138138年世界上最大的三体帆船航行Prout PT
Breaking records, Prout has successfully infused all three hulls of its innovative sailing trimaran, the PT-138, using epoxy resin at the yard in Zhuhai (China). 普劳特打破纪录,已经成功地注入所有三个船体的创新三体帆船航行,pt - 138,用环氧树脂在珠海(中国)院子里。The Prout Trimaran 138’ is designed and constructed as an all-composite shallow draft sailing trimaran with a 46 ft beam with a very small draft of only 1.52 m. The hull and deck are to be constructed utilizing Prout International’s mold and when the Prout PT 138 is launched it will be the largest sailing trimaran in the world.Prout三体帆船138的设计和建造是一个复合浅吃水三体帆船航行46英尺梁与一���非常小的只有1.52米的草案。船体和甲板构造利用普劳特国际普劳特的模具,当工党138年启动,它将是世界上最大的三体帆船航行。
Trimaran Prout PT 138 infused hull普劳特三体帆船PT 138注入船体
This 138 ft trimaran has been designed to conduct extended offshore passages with her owner and may also be used for luxury yacht charters.这个138英尺三体帆船设计进行扩展海外经文和她的主人,也可以用于豪华游艇包租。
Prout Pt-138s General specifications:普劳特pt - 138通用规格:
LOA: 138ft贷款:138英尺
Beam: 46ft.梁:46英尺。
Displacement: 32,767kg.位移:32767公斤。
Draft: 1.52m.草案:1.52米。
Rigging and Sails:索具和帆:
Mast Height: 43m.桅杆高度:43米。
Mainsail 257m2主帆257平方米
Genoa: 259m2热那亚:259平方米
Gennaker: 271m2Gennaker:271平方米
Equipment:设备:
Water Tank: 3,785 l水箱:3785 l
Fuel Tank: 15,142 l油箱:15142 l
Engine: 625 cv发动机:625简历
About Prout International普劳特国际
The Prout name has been synonymous with quality yacht construction since its founding in 1954 by Roland and Francis Prout. Prout名称已经等同于质量游艇建设自1954年成立以来由罗兰和弗朗西斯·普劳特。Through its demanding specifications and relationships with its Far East shipyards, Prout has been able to continue producing only the highest quality yachts with the finest materials at a fraction of the costs incurred at facilities elsewhere. 通过其要求规范和关系远东造船厂,普劳特只能够继续生产最高质量的游艇用最好的材料在设施费用的一小部分。Using this competitive advantage in conjunction with Prout’s extensive IT and R&D work, Prout is able to provide labor intensive, high-end touches to its yachts, including compound curved high tensile safety glass in the salon windows, high-grade inlaid woods, genuine hard-wood flooring, natural golden teak decking,and granite countertops.使用这种竞争优势与普劳特广泛它和研��工作,普劳特能够提供劳动密集型、高端游艇触动,包括沙龙复合弯高强度安全玻璃窗户,高档镶嵌森林,真正hard-wood地板、自然金柚木甲板,花岗岩台面。
2014-7-15 21:06
洪运来 楼主 来自: 北京
2014-7-15 21:14
42米!这么大!这造价
2013-12-16 18:42
2014-7-13 15:12
2014-7-13 18:26
2014-7-14 21:10
找到了么?
2014-7-15 21:00
LOA: 138ft贷款:138英尺
Beam: 46ft.梁:46英尺。
Equipment:设备:
2014-7-15 21:06
2014-7-15 21:14
