[求助] 求问drumbler是哪种帆船呀?
发表于 2021-2-23 21:26 | 显示全部楼层 |阅读模式 来自: 黑龙江哈尔滨
求问:drumbler 这种是什么帆船
只查到是:A small ship of a type used in coastal waters in the late 16th and early 17th cent.
(https://www.oed.com/view/Entry/58018?redirectedFrom=drumbler#eid)
发表于 2021-2-24 10:04 手机发布 | 显示全部楼层 来自: 山东青岛
回帖奖励 +5 贡献
打不开,您能否转帖到跟帖
发表于 2021-2-24 14:12 | 显示全部楼层 来自: 加拿大
drumbler
(also drumler)
Pronunciation /ˈdrʌmb(ə)lə/ /ˈdrʌmblə/
NOUN
historical
A small ship of a type used in coastal waters in the late 16th and early 17th century.
The precise form of the ship so called has not been identified; they were used for transport and also for piracy.
Origin
Late 16th century; earliest use found in Richard Hakluyt (?1552–1616), geographer. From Dutch †drommelaer, †drommeler, apparently a variant or alteration of †drymmelaer kind of cargo vessel (1570; also †dremmelaer, perhaps from dremmelen to linger, dawdle + -aar, perhaps so called on account of its slow speed, although not enough of the ship's construction is known to confirm or reject this interpretation.
这个东西包括这个词语都从现代消失了,你得找考古家来研究这问题。。。比如联系下荷兰海事博物馆的学者他们可能有知道的。
方便的话可以加您微信么~ 最近在研究帆船术语 想多向您请教下:lovelines  详情 回复 发表于 2021-2-28 22:55
好哒!这个词确实太古远了 不过还是很感谢回复呀!  详情 回复 发表于 2021-2-28 22:51
 楼主| 发表于 2021-2-28 22:51 | 显示全部楼层 来自: 黑龙江大庆
begun 发表于 2021-2-24 14:12
drumbler
(also drumler)
drumbler
(also drumler)
 楼主| 发表于 2021-2-28 22:55 | 显示全部楼层 来自: 黑龙江大庆
drumbler
(also drumler)
GMT+8, 2025-2-5 19:44 , Processed in 0.302508 second(s), 44 queries .
© 2001-2024 Discuz! Team.
