[求助] 打雷怎么办
发表于 2018-9-6 20:24 | 显示全部楼层 |阅读模式 来自: 广东广州
帆船航行中遇到打雷天气应怎样操作。
发表于 2018-9-7 16:55 手机发布 | 显示全部楼层 来自: 中国
如果怕打雷请按以下步骤采取措施:1.闭眼。2.捂耳朵。3.张开嘴。4.大叫“我的妈呀,吓死我了!”如果还不见效请无限重复第四步,直到雷打完!
发表于 2018-9-8 00:07 手机发布 | 显示全部楼层 来自: 浙江
带上头盔……改上被子……
出海钓鱼是人生一大乐趣
发表于 2018-10-31 10:35 | 显示全部楼层 来自: 亚太地区
Lightning is one of the big FAQs on yachting forums. Do a search to check out previous threads on this site.
Yachts do occasionally get hit, though less often than you might think given the apparent vulnerability of the mast. Most reports come from Florida because of the concentration of yachts and the number of severe thunderstorms there. It rarely seems to result in death or the loss of a yacht, but almost always in serious damage to electronic gear and electrics generally, and localised scorching.
There are many theories about (i) how to repel lightning (ii) how to ground it safely if struck. For ever well-argued, convincing case that you can find on the internet, you will find another equally authoritative arguing the other way. There are a number of protection devices available of questionable efficacy - rarely seen in practice, certainly in the UK.
The one thing everyone agrees on is that if you are caught out in a severe thunderstorm it is advisable, if possible, for all crew to remain inside the cabin.
Read more at http://www.ybw.com/forums/showth ... ojGAXm35Kyyg6s3Z.99
做法和楼上说的一样
发表于 2019-5-21 10:00 | 显示全部楼层 来自: 广东
要马上关闭所有电源,然后找一个裤裆钻,聊斋都是这样教的。
GMT+8, 2025-12-22 18:08 , Processed in 0.162962 second(s), 49 queries .
